jak wam cykają O1 130 KM na pompowtryskach?
  • dariuspolo
    • 1168
    #26
    Zamieszczone przez ciaglejade
    tylko o kod wyposażenia tj. ten ciąg 3-literowych(cyfrowych) oznaczeń na wklejce
    ...wyposazenie to cala masa kodow ponizej(jest ich cala masa nie spotkalem na razie rozpiski w internecie, na gorze pierwsze trzy to oznaczenie silnika (np. AGR, ALH), drugie trzy to oznaczenie skrzyni (np.EGS, ERF).
    [ Dodano: Nie 30 Lis, 08 22:50 ]
    ...tutaj masz rozpiske wyposazenia z mojego auta´:
    X3B national sales program Spain (FBU)
    A8D luxury equipment
    G0C 5-speed manual transmission
    K8D Station Wagon Variant/Avant
    T8U 4-cylinder diesel engine 1.9 L unit 038.G
    AZ0 vehicle with standard production scope
    B0A component parts set without country-specific design requirement
    B15 type approval Spain (Andorra, Balearic Islands, Canaries)
    C00 operating permit, initial registration
    C6F alloy wheels 6J x 15 style not designated; 1J0 601 025 offset 38 (five-hole)
    E0A no special edition
    F0A no special purpose vehicle, standard equipment
    G33 front shock absorption
    H6S tires 195/65 R 15 V
    J0L battery 340 A (70 Ah)
    L0L LHD vehicle
    L09 suspension range 09
    MN0 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIEU 3 base engine is T8U
    N2M fabric seat covering
    QA0 without child seat
    QG1 service interval prolongation
    QJ0 without aluminum/chrome work package
    QS0 without electronic map cooling system
    QV0 w/o TV reception/digital radio reception
    Q1A standard seats
    U1A instrument insert with km/h speedometer,clock, tachometer and trip odometer
    VC0 w/o remote-controlled garage door opener
    VK0 air duct, standard
    V0A tires w/o specification of tire brand
    0AE front stabilizer
    0A2 four doors
    0BC rear stabilizer
    0CH vehicle class differentiation 1U0
    0EJ installation differentiation for transmission MQ 250 vehicle components
    0FA standard manufacturing sequence
    0F3 fuel system for diesel engine
    0GE emissions concept EU 3
    0G4 cable gearshift
    0KA without stickers and badges
    0L2 electric throttle actuation
    0NB nameplate set in base trim
    0N5 standard rear axle
    0RA without ignition/starter switch locking system
    0SU labels/plates in Spanish and Italian
    0TA without floor mats
    0VD Spanish owner's manual
    0YZ without determination of weight categoryfor rear axle
    1AJ anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
    1C1 antifreeze up to -25 degree celsius tolerance up to -30 degree C
    1D0 without towing attachment
    1EX VIN plate
    1E0 without activated charcoal canister
    1G2 steel spare wheel with original equipment tires
    1H0 without proportioning valve
    1JH rear shock absorption
    1KP disc brakes, rear
    1LS front disc brakes with integrated adapter
    1MP steering wheel for airbag system
    1NL covers for alloy wheels
    1N6 power steering
    1PC wheel bolts with anti-theft protection (unlockable)
    1Q0 without mass damper for steering wheel
    1SA without additional engine guard
    1T0 w/o first aid kit and warning triangle
    1X0 front wheel drive
    1Z2 increase in initial standard fuel filling
    2B1 additional exterior noise suppression
    2C5 axial and vertical adjustable steering column
    2D0 without cd enhancing underbody panel
    2G8 filler neck module 2 without insert
    2LB fuel tank with special material treatment (fluorination)
    2UA standard design
    2V1 dust and pollen filter
    2W0 fuel filler cap
    3AF outer right rear view mirror: convex, powered, heated
    3BS outer left rear view mirror: non-spherical, powered, heated
    3B0 without additional child seat anchor
    3CA without partition
    3C1 static lap belt, center rear
    3FA without roof insert (standard roof)
    3GA without cargo area
    3H0 without backrest release for front seats
    3J7 articulated and height-adjustable headrests for front seats
    3L3 height adjustable front seats
    3NW rear seat bench/backrest, split folding with center armrest
    3QT 3-point seat belts with tensioner and height adjustment, front
    3Q1 rear headrests
    3S2 black roof rails
    3U2 sliding trunk cover
    3V0 without child bench seat
    3X0 without load-through provision
    3ZG 3-point seat belts, outer rear with height adjustment
    4A0 without seat heater
    4B1 protective side molding
    4E0 tailgate/trunk lid unlocking from outside
    4GC windshield, tinted with sun band
    4KC side and rear windows tinted
    4K3 radio remote controlled central locking operated from inside and safe securing
    4LA without controls
    4L0 non-dipping breakaway inside rear view mirror
    4M6 cup holder
    4N1 padded dashboard
    4P2 rear floor panel module, type 3
    4R4 electric rear windows
    4SC left vanity mirror with cover
    4TC right vanity mirror with cover
    4UE airbag f. driver a. front seat passenger
    4U1 luggage nets/pockets on backrests
    4W0 without cassette and CD storage unit
    4X0 without side airbag
    4Z3 lockable glove compartment door, with light
    5C0 without special body measures
    5D1 Remote control and central locking system
    5K1 paint preservative (wax)
    5TC without decorative inserts
    6A0 without fire extinguisher
    6E3 center armrest front
    6FB exterior mirror housings and door handles in body colour
    6KA radiator grille
    6M2 load safety net
    6N0 without mud flaps
    6PA plastic hand brake lever handle
    6P1 license plate bracket rear (ECE)
    6Q1 plastic gearshift knob/handle
    6R1 leatherette gearshift boot
    6SC tufted trunk floor covering
    6W0 without license plate bracket front
    6XD outer rear view mirrors: powered, heated
    6Y0 without cruise control warning system
    7AA electronic vehicle immobilization device
    7A0 without CD changer/CD player
    7E0 w/o heat accumulator/auxiliary heating
    7N0 without tray on roof liner
    7PB platform group class 2
    7P0 without lumbar support in front and rear seats
    7QA without CD ROM
    7Q0 without navigation device
    7X0 without park distance control
    8AA without radio
    8BN halogen headlight for left-hand drive
    8CC speedometer sensor without seal (electronic speedometer sensor)
    8F2 side turn signal lights
    8GD alternator 90A
    8K0 without special low beam mode
    8L3 roof antenna
    8M1 rear window wiper and washer system with intermittent control
    8NA without parking light warning light
    8N4 windshield wiper intermittent control with potentiometer (four speeds)
    8QK key for locking system
    8Q1 headlight-range adjustment
    8RM eight loudspeakers (passive)
    8R1 center high-mounted stop light
    8SA taillight assemblies, standard design
    8S4 two reading lights front, two rear
    8TC rear fog light for driving on the right
    8T0 without cruise control system (CCS)
    8WD integrated front fog light
    8W0 without washer fluid level indicator
    8X0 without headlight washer system
    8Y1 two-tone horn
    8Z5 engine cooling system, type 1
    9AK automatic air conditioning with sun sensor
    9A0 without taxi alarm system
    9BC display and warning tone f. opened doors
    9D0 without preparation for two-way radio installation
    9J0 without supertone system and tone sequence control
    9M0 without auxiliary/parking heater
    9P1 seat belt warning light, electric contact in buckle
    9Q1 onboard computer
    9TB additional warning lights (door area)
    9T0 without heated washer nozzles
    9U1 brake pad wear indicator
    9W0 w/o car phone preparation/installation
    9X0 without heated door lock cylinder
    [ Dodano: Nie 30 Lis, 08 22:53 ]
    2pac ale w twoim dekoderze nie ma kodow wyposazenia.
    T4 CARAVELLE AXG 150PS/295Nm
    SEAT ALHAMBRA BLT 180PS/385Nm
    Zuzycie paliwa
    • metrotest
      • 506
      • CCZA 2.0 TSI RS 200 KM
      #27
      Zamieszczone przez Ziomal
      Z tego co patrzę , to rzadziej coś się dzieje w 130 jak np w 110 czy 90.
      A może po prostu 130 było dużo mniej niż 110 czy 90 i stąd takie wyniki :roll:
      • Ziomal
        • 5841
        Zamieszczone przez metrotest
        To prawda , ale mimo wszystko jest trochę tego i nie mówię tylko na podstawie tego forum
        Jest O1 1.6 BFQ
